reduce engine power light
Old 02-13-2008, 09:23 AM
Biggin's Avatar
Default reduce engine power light
this morning i got into my truck 2 start it and the light come on and it was idleing up and down... ps i have a bad battery if that has anything to do with it
Old 02-13-2008, 03:30 PM
DrX
DrX's Avatar
Low ignition voltage will cause an electronic throttle fault triggering Reduced Engine Power mode.
Old 02-14-2008, 09:09 AM
Biggin's Avatar
aloso what should my truck idle at rite now its at 400 or 450
Old 02-14-2008, 10:08 PM
cwalker2006's Avatar
my friend had a bad batttery or a connection was losse i cant remeber. anyways he had the same problem it was ideling low and had no power whatsoever. change your battery and that should fix it... should idle around 500 if im not mistaken.
Old 02-14-2008, 10:17 PM
DrX
DrX's Avatar
Here's a 2004 4.8 idle table:
ARC
57
02-21-2022 10:54 AM
Ketis
07-23-2015 12:37 PM
atxlt
07-20-2015 11:06 PM
projectnightcrawler
07-19-2015 11:30 PM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: reduce engine power light
