the reduced engine power blues
Custm2500's Rude Friend
The question is why did it go into REP mode... On an 05 I would think maybe you have the dreaded wiring issue that has plagued so many of the electronic throttle body trucks. I know there is a TSB on it. You should be getting some type of code setting in order for it to go into REP mode.
How are you checking for Codes??? EFI LIVE??? Are you looking for Pending as well as permanent codes???
I have replaced all the wires, terminal ends (soldered them too), and plugs to the X-link. I am checking my codes with the Flashscan. I am not sure about pending VS permanent. I just hit F3, F2, F1, F4 for all DTC's. I only have C0035, and P0102 as I am running a SD tune. I get the P0102 as soon as it starts, and I have been told that is normal.
If I had to guess, I think it is the throttle body. I think the motor isn't strong enough to hold the blade. I know it is a long shot, but that's all I can think unless someone has other suggestions. It seems like this is only happening to people with superchargers and moving a lot of air.
He Fixed the wires to rule that issue, out because 1 or 2 tested bad, replaced the X-link, and after that he tried a different TB and it fired up with no Issues.
Well I swapped to the 87mm, and went WOT without going into REP. So it must have been the TB. What really surprises me is that you really need to force the throttle blade with your hand in order to get it to go into REP with the key on engine off WOT. I did it several times with my dad running the throttle, and it acted just like it does when I am driving it. I had him try it while I was running the throttle, and he wouldn't even push it that hard. He thought it was going to break. I didn't realize how much air pressure was on that thing. Maybe when I get time I will put a vacuum gauge on it, and see what it reads at WOT. Let's see if it stays this way with the 10% OD crank pulley.
Good deal!!! The motor in the TB must not be strong enough for the turbulence the Boost creates... I wonder if there are any tricks that would help reduce the pressure on the blade yet not affect performance. I also wonder if any of the aftermarket throttle body's suffer from the same issues over time...
ARC
57
02-21-2022 10:54 AM
lxcoupe
07-30-2015 02:42 PM
Offroadunleashed
07-20-2015 02:25 PM
wheeliE-maxx
07-19-2015 05:37 PM
