Reduced Engine Power p0101 p0106
Ok I have a 6.0 lq4 full bolt ons No stall, and I recently put a 232/234 torquer v2 Cam which I havent been able to take to get tuned bacause of the same problem my tuner cant get an acurate reading becaue of the MAF
![Bomb](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_bomb.gif)
17,16,15,14,13,12,11 Drvr
sounds like your maxing out your map sensor at idle causeing the other problems, he needs to set the max to 75 and leave the min stock just in case it does it fail.
p0121 is the map sensor code.
Resident Retard
Since your getting a MAP and MAF code, and then it goes into REP, I think it might be the values in your MAF rationality test table... I believe the REP gets set because there is toooo big of a difference between your MAP and MAF.... Did your tuner tune both your VE and MAF tables or just the MAF table?
Hello Dave
Bingo. Something isn't right with the tune. If either VE or MAF were changed to values they should be, then the MAF Rationality test would not need to be changed. Mechanical problem could be faulty MAF (replaced), Faulty MAP (P0106 lends to this), plugged converter(s) (both codes could be caused by this).
If there was a broken wire, P0102 would trip... low frequency code.
