replacing ignition lock cylinder 2003 passlock relearn?
hello all, Im going to be replacing a ignition cylinder lock on a 2003 chevy silverado. Im just replacing the cylinder not the ignition switch. I have a replacement lock and set of keys from oreillys. Ive never done this on a later model truck. I know it should be pretty straightforward (take column cover off, turn key forward,push pin in and release cylinder from housing. ) Is the security system gonna give me fits? Its my friends truck and I dont want to leave it stranded at my house.
thanks
thanks
correctly? Is there anything I should be cautious of? passlock sensor or anything? Ive never messed with a cylinder with the security system on it.
appreciate the help
matt
appreciate the help
matt
Custm2500's Rude Friend
On My 2000 there is a little pin switch that sticks down. It has to be removed by releasing the tab and twisting it sideways. Other wise I could not get the new cylinder back in. Sorry, I don't have any pictures.
Make sure you get all the screws on the cover to remove the upper half. There was separate screw that was hard to see that I missed after removing the lower cover.
Take the old cylinder apart and remove 1 tumbler at a time to get the key code. Write each number down in sequence as you do it.
smokeshow
08-23-2015 08:23 PM
Fast86z
08-23-2015 12:35 AM
atxlt
07-20-2015 11:06 PM
