rpm rise when putting in gear...
Need help with tuning out a quirk, lol. When the engine is cold and put into gear the idle rpm rises 300-400 rpm then drops back down to normal once "fully" into gear. Example: When started the engine idles at approximately 900rpm when I move the shifter to drive or reverse it rises to 1200-1300rpm then drops back down to 900rpm. This only happens when engine is cold. When warm it is fine. This is a 2002 pcm that pcmforless originally tuned. If anyone has a clue where to start I'd appreciate it. Thanks.
Originally Posted by 1SlowHoe
Yeah, what he said. Why idle so high? Aren't most running at 600? I was at 500 but had issues with my A/C cpmressor so I bumped it up. Just wondering why you went to 900.
Originally Posted by LBSBLOWN
Try looking at the IDLE SPARK ADVANCE tables Idle in Drive & Idle in Park/Neutral and bring them closer together and that should solve your problem.
AHelm3
04-08-2016 07:51 AM
BlackGMC
08-17-2015 07:07 PM
GMCtrk
38
08-09-2015 08:50 PM
Mossyoakglock
07-17-2015 08:30 AM
