Running 35* timing with no KR!!!!!!!!!!
Old 06-03-2006, 08:26 PM
  #21
You should try adding 2ms to the whole bottom of the scale. From where its at 6ms the rest of the way. I wish I could post a screen shot somehow, but I dont know how.
Old 06-03-2006, 08:27 PM
  #22
Base dwell multi. is set at 1 all the way.
Old 06-03-2006, 08:30 PM
  #23
TouchOfEvil04's Avatar
So it hits 6ms at a certain point alread right?Have it changed so that all the scales that are lower than the 6ms area up to 6ms correct>?Then have the multi set up to 1.0 correct?
Old 06-03-2006, 08:34 PM
  #24
Your right on the money. I'm just bad at explaining things. LOL
Old 06-03-2006, 08:37 PM
  #25
Nah you did fine.If you ahdn't i wouldn't have gotten it right heh.Thanks dude this is something i'm gonna have to get my tuner to take a look at for me when i get him to fix my gear ratios since i'm doin a gear change to the ol truck.
Old 06-04-2006, 12:48 AM
  #26
greentahoe's Avatar
Where in HPTuners is this located? Im assuming in the Engine>Spark Dwell... and then where?? Under Base Dwell time it is listed by volts and RPMs so where did you make the changes?? Thanks for the tip!
Old 06-04-2006, 06:38 AM
  #27
COLDZ71's Avatar
I'm stationed at Brunswick NAS. I "should" get out in July if they dont extend me again. The sooner the better.
What is the local "scene"? Where is Milo?
Welll, there really isnt a local scene. Just joking with ya. Milo is right in the center of Maine. Just inside the southeast tip of Piscataquis county.
Old 06-04-2006, 08:18 AM
  #28
I went from 10 volts all the way down and added 2.2ms. I also made sure the "base dwell mult" was set at 1.0 and the "mult vs. map" set at 1.0.
Old 06-04-2006, 09:56 AM
  #29
speedy02's Avatar
On the "base dwell muit" you set it to 1.0000 across the bord from -40 to 284?
Old 06-04-2006, 11:41 AM
  #30
yep sure did.
Quick Reply: Running 35* timing with no KR!!!!!!!!!!
