Running Lean
Old 01-22-2011, 01:55 PM
closet red neck's Avatar
Question Running Lean
Okay guys, I'm cruising @ 70mph, let off the throttle(coasting) and the wideband goes lean. But while doing so the truck jerks like as if its starving for fuel. If I just barely touch the throttle, it stops jerking. Would the the throttle cracker, follower or idle running air flow take care of this?? I know that fuel needs to be taken away when letting off the throttle but i shouldn't do this. It just started doing this a few moths ago. Also it gets worse when going down a hill.
Thanks
James
Old 01-22-2011, 02:00 PM
I have a gauge for that
Atomic's Avatar
Sure its not DFCO?
Old 01-22-2011, 02:42 PM
Never thought of that........but could be it. What disable it??
James
Old 01-22-2011, 02:48 PM
Well not disable it but play with the ramp rate or hold time???
James
Old 01-22-2011, 03:03 PM
Atomic's Avatar
I would just turn it off completely at first to make sure that is it...then if it is you can play with the entry and exit settings
Old 01-22-2011, 03:11 PM
Ok, to turn it off just zero out everything??? I'm new with the DFCO table.
James
Old 01-22-2011, 03:14 PM
The hold time is 0.000, entry ramp rate is 0.050 and the exit ramp rate is 0.013
James
Old 01-22-2011, 04:09 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Its probably because you dont answer your phone when people call
Old 01-22-2011, 04:34 PM
Atomic's Avatar
Just set the enable temp to 250 or something higher than you will reach.
Old 01-23-2011, 08:40 AM
James
Whats funny is that the above stated values are in the stock 6.0 and LS2 tunes I have but theyre zeroed out in all of the stock 5.3 tunes. I'm gonna zero them out and see if that fixes/helps the problem.
James
Quick Reply: Running Lean
