scaling ifr table
Old 07-18-2005, 09:00 PM
TURBHOE's Avatar
no that is a good ?? becouse i have the marine ones. sorry its been so long since i've even attempted to tune anything its hard to remimber what all i did mine don't see but like 20% max it seems like, becouse my turbo isn't on yet.
Old 07-19-2005, 12:11 AM
02sierraz71_5.3's Avatar
thanks for the help what I did was to scale the injectors like this based off
Injector Rated Fuel Pressure: 58
Your Fuel Rail Pressure: 58 (this varies so I just took a mean value)
Injector Rated Flow Rate 30
kpa
0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
ifr
30.00052906 30.18750146 30.37332291 30.55801442 30.74159634 30.92408844 31.1055099 31.28587935 31.46521487 31.64353405 31.82085397 31.99719125 32.17256204 32.34698206 32.52046662 32.69303059 32.86468849
at wot it got the inj down to 17.5 ms which is what it is running SD puts me between 85 to 100% duty cycle depending on where I shift which isnt the best but its better than 120% which is what I was at with the stock 5.3 25lbers
this maf is a mother to tune and it reaks havoc on everything else its a saint and a devil at the same time I can run more timing and get better times and mpg with it but its such a PITA to tune anything with it on. My inj pulse width is an example of that.
thanks again for the input
Old 07-19-2005, 10:07 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Originally Posted by 02sierraz71_5.3
are there any benefits to scaling them?
I have noticed I get higher inj pulse widths wot running a tuned maf vs SD I dont have enough knowledge to put it all together but was thinking the ifr table could help keep the wot pulse widths lower with it being scaled. Im getting the same pulse width with these 30lbers as I was with the 25lbers,WTF? I tried retuning the maf and thats not the issue its dead on as is my ve table. So why is it that my pulse width is lower running SD vs maf?
If you have a vacuum referenced regulator, *do not* build the curve. The curve is for returnless fuel systems, that do not have a vac ref'd regulator. The VRR makes the same curve when you need it based on vacuum / boost.
Old 07-19-2005, 11:25 AM
All late model GM engines have return systems on them, dont they?
Old 07-19-2005, 11:26 AM
I AM A MOTHERF*CKER
no, mine doesn't, and if your stock IFR tables have a single value in them, neither does yours.
You can also check to see if there is a vacuum ref'd regulator on your driver's side fuel rail.
AFAIK, trucks went returnless in 04.
Old 07-19-2005, 12:20 PM
TURBHOE's Avatar
ok i had i bacwards my bad. like i said i'm a long ways from home and haven't even got to drive my truck in two months. i think they went returnless in 03 though becouse i think parish's is returnless also.
Old 07-19-2005, 01:06 PM
I AM A MOTHERF*CKER
Mine is an 03 They must have done some returnless, and some return. Weird, but SOP for GM
Old 07-19-2005, 01:38 PM
TURBHOE's Avatar
this is true. i could be wrong but i could've sworn that he said it was. thats why he got the two big intank pumps instead of the inline. i think we've discussed this before becouse some 03's had it and some didn't
Old 07-19-2005, 02:10 PM
the stock values where not scaled they were the same plus there is a vaccume reference line attached to one of the rails. So I set the ifr table to 31 across the board.
Are the 8.1 truck injectors exactly 31 lb/hr?
Some say 30 some say over 31.x
Vortec350ss
01-12-2016 10:36 PM
Aaron Arceneaux
12-21-2015 02:54 PM
legerwn
56
11-15-2015 10:21 PM
Tydriver
45
10-23-2015 09:19 PM
Quick Reply: scaling ifr table
