SD tune not failing maf until engine runs for a few seconds?
Mine used to do the same thing till I stumbled across a fix either here or on HPT forum. IIRC it had something to do with the maf table and placing a large value in the first column. I did a quick search but didn't find exactly what I was looking for but the following linked thread has a similar solution. Check posts 20 and 35...
https://www.performancetrucks.net/fo...g-tune-520534/
Mod with training wheels
I'm gonna throw in a wild suggestion and say it may not have anything to do with the conversion to SD at all. I've had an issue with I don't know how many vehicles with various operating systems and engine setups, boosted and NA alike, where the car/truck will run fine until you write in a new calibration. On first crank after the write, it runs like absolute ****. On older P01 and P59 pcms, the vehicle is borderline unresponsive. Idles very low, cuts out, often dies, and does not obey throttle input. For some reason it eventually 'catches' and runs/idles normally and never has any more problems on subsequent startups, that is, until I write in another tune. Sometimes this post-write tomfuckery goes on for a few seconds and 'catches' and runs fine; sometimes it lasts longer. I've been stranded for a half hour before because a truck refused to run after dozens of start attempts. On some vehicles this doesn't happen at all. I thought it was isolated to older stuff until I tuned a 2012 corvette recently that had the same behavior. Only that car was actually responsive to throttle input and drove normally.
My speculation at this point is that it's an interface problem. This all started happening after a firmware update. I've been meaning to bug the guys at HPT about it for a while now, but keep forgetting until it pops up again lol.
SSpeeDEMONSS
11-09-2015 06:50 PM
Stainless Works
11-06-2015 07:42 AM
Suburbazine
11-03-2015 08:28 PM
