SD Tuning - 1st log Mafless - Long
#31
LS1TECH Sponsor
Originally Posted by dewmanshu
WOO HOO!!! MAn I hate the whole increments by 10 on the kpa. UGH! anyways...WOO HOO!!!GET TUNING!!!
#32
I didn't realize I'd loose resolution going into this. They do state clearly that you will have 10KPA resolution, went back and looked, but they post up a big fat picture of a 98 LS1 VE table with full 5KPA resolution on the site. Probably not enough space in the pcm with the later OS's for it and some of the RTT stuff I'd say.
I'll start tuning shortly. Can't wait!
#33
Moderately Differentiated
it's time to get bigger PCM's GM!!!You listening "big man"?!?!?!
#36
yeh a little misleading, but you gotta read. I have an '02, but helping others with 03+ is kinda different IMO. I have to be more patient with changes. Sometimes you think you have a cell locked down on averages, but then you really don't. I suggest lots of cell counts on the cells you change.
#38
Originally Posted by agreif
So you plunked down for the road runner too? How do you like it so far?
#39
Couple questions so far. I also posted it up on HPT forum.
1> Can someone give me a good method for smoothing? Smooth between vertical, horizontal and selection. Do all, one or the other? How often?
2> Looking ahead and reading the help. Obviously I won't put the MAF back on it but I assumed I would enable closed loop fueling again. Enable STFT'S and LTFT's. Re-enable COT and IAF fueling corrections etc... Everything but turning the MAF back on. The help file doesn't mention doing this.
3> I am also getting large hits of KR that I don't understand. Never had this before and don't think the new OS or tuning I'm doing has anything to do with it. Hoping that maybe I've got a bad tank of fuel. I am going to run it out and try another tank but I really don't know for sure. I am attaching the last logs as I am lost to what would be causing it. Hopefully some of you GURU's could have a look and suggest something.
Tune, log and config
#40
LS1TECH Sponsor
