Service Engine but no code?
Old 10-04-2010, 03:30 PM
SILVY303's Avatar
Ok that would be great just tell me where..
Old 10-05-2010, 04:56 PM
Where's the Beef?
viciousknid's Avatar
Looks like I need to be there by 1pm on Friday so after I'm done with that. If you aren't familiar the SSI office is at Shepherds mall. PM me your number and I'll call you when I get finished.
Old 10-05-2010, 09:42 PM
Mrgoodwrench3's Avatar
Try doing a scan when the light is on and leave the engine running. The cheap scanners use what is called Global OBD II protocol. It will usually pick up any current DTC info. Many do not show history.
Old 10-06-2010, 11:19 AM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by 00ChevyScott
wouldn't a short cause it to not light up?
If the light has constant 12v and the PCM turns it on by grounding it, then a short on the ground side of the circuit would leave the light on at all times with no codes...I've seen this happen on Toyota's in the past. Not sure if the GM MIL works the same way though. As mentioned, if it's a manufacturer specific code though, the generic AutoZone scanner won't pick it up...
Old 10-06-2010, 10:00 PM
eallanboggs's Avatar
There are P, U, C and B codes. Yours could be an Enhanced Code(manufacturer specific). All manufacturers have enhanced codes as well as generic ones which are required by the OBDII EPA mandate. If you're going to fix cars and trucks you need a decent scan tool. You can get a good PC based scan tool for a few hundred dollars these day. Most handheld units are very limited even though the TechII is handheld and costs thousands. If you work on GM TechII is the way to go. GM is phasing out the TechII and will soon use PC based.
Old 10-06-2010, 10:56 PM
PT's Slowest Truck
budhayes3's Avatar
I have two generic scan tools, but the one has a GM Enhanced Upgrade and includes knock retard, while the other is just OBDII Generic, but will read ABS codes for GM, Ford, and Chrysler...some day I hope to EFILive though...
Old 10-07-2010, 12:17 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Hmm, wild shot in the dark here.....
Are you sure it isn't the oil change light?
Old 10-07-2010, 12:45 AM
I have a gauge for that
Atomic's Avatar
Pretty sure it will just flash "CHANGE ENGINE OIL" on the display and there isnt a specific light for it....thats how mine is anyway (04).
Old 10-07-2010, 12:56 AM
PT's Slowest Truck
budhayes3's Avatar
That's the way my 99 is also...
Old 10-07-2010, 01:03 AM
That's the way my 2001's are also. Some of the newer GM's have a light on the dash that shows an engine with a wrench next to it, and it stays on while driving (after the message center goes out.)
I can't tell you how many customers brought their cars in for "check engine lights" that were actually "change oil lights", so I thought I'd ask. Apparently not the case here.
Quick Reply: Service Engine but no code?
