Shift point settings
Using HPT the truck has 3.73's with 30.81 tires. The current settings are 1/2 - 5900 - 35 and 2/3 - 5500 - 68. I want to change the 2/3 to 5800, but im not sure what the MPH on either should be.
Do i really need to be scanning to do this or can it just be changed.
if ur not sure just up the rpm add 2-3 mph and take it for a run.. log the run and c where u shifted.. if ur at 5700 add another mph if it cut off on the shift and it shfted at 5800 take a mile off. this is how i usually do mine.. just my method but im no tuner so i migh be wrong..
Its not my truck, its a guys i just done 05 fans on. 02 silvy Z71 ECSB, OBX LT's w/ Y pipe, volant, and some kind of muffler.
Im just playing around with it some to get the hang of things, i may call him one day and see if he will let me add the changes i make....lol
I think Allen said he has my truck shifting at 6400 which was where it started to level off he said.. plus im still on stock rod bolts.
8 Second Truck Club
Unfortunately, I've tuned more than one vehicle, including my own where this does not alway work. On my truck especially I have to dial in shift points using the mph table. For example, I can command a shift at 6500 rpm (about 60 mph) and 50 mph (about 5000 rpm), it will shift at 5000 rpm. So what I've had to do is set the rpm shift point where I want it and then sneak up on the mph shift point. Once I did this, it shifts exactly where I tell it to every time. My truck has been like this since day one.
FormerVendor
While this is how it should work, it does not in some applications. HPT says that in order to shift it must meet both the rpm and mph criteria. So theoretically you could just use the rpm number to set WOT shift points as long as the WOT mph shift points where lower.
Well put sir.
With the 6L80E's they pretty much basically only respond to the shift speed mph settings, changing just the rpm shift point on these trans does next to nothing.
