Shift point v. fuel cutoff problems
Hello Dave
Originally Posted by 1SlowHoe
The 1-2 is set to 36mph the 2-3 is set to 67mph. I guess I need to lower those up a bit? That way the speed will be met before I reach the rpm I want to shift at? What has primary control, the speed or the rpm? I think its the rpm from what I've seen.
I have 4.10 gears and 32" tires.
Hello Dave
Will setting the WOT tables MPH to zero work? (table D910....etc)
Then it will only be looking for the rpm I have set to be met correct? So set D940...etc to 6100 and the fuel cutoff at 6500?
Something to keep in mind here is that if you have an eletronic throttle body (such as an 03' or newer), you will have 2 rev limiters to set. You can raise one and still hit the other. If you have a pre-03' truck with traction control you'll also have an etc.
