softening DFCO enable
I was playing around with the DFCO settings yesterday, apparently it has never worked on my truck.. Anyways i got it working but when it enables it is very noticeable, almost like someone put on the brakes.... Is there anyway to soften it or make it less noticeable when it engages? Ramp in rate or would raising the commanded timing help? Currently my ramp in rate is 0.07 and timing is 5*....
thanks in advance...
Personally Corey I've never seen a noticeable difference having it enabled other than the severe "braking" effect. I disabled mine and never looked back. When you go off throttle and back onto the throttle I never liked the jerk or lash that the DFCO caused. It's much easier on your drivetrain to leave it disabled.
lxcoupe
17
08-26-2015 05:00 PM
Closer_2001
07-21-2015 03:25 PM
KySilverado
42
11-24-2006 10:45 AM
