Speed density tune...Why???
#31
I guess i should state that SD is accurate when your out of MAF range and your fooling the tables. Its def. more accurate in my case
Ive also been very impressed with another similiar setup truck, SD tuned, running a decent sized but not too crazy blower cam that was N/A.
I dont feel you have to Go SD on an N/A setup, but if you do you should learn how to tune because as the weather changes so will some driveability items.
Now that its cold i have to apply a lil throttle to get my girl to fire up. I just havent tweaked that aspect yet as i wont be driving it this winter.
#32
When tuning OLSD allot of the fueling changes due to weather can be altered with the charge bias table. There is no magic #'s for this table from what I have seen, they very by setup. Tuning this table is a pita because everytime you change it it throws your VE back out of wack. I have been 2barOLSD for 5yrs now and love it. I even ran one season NA on my 2bar OLSD tune and still ran great. ( in between blower setups). I am not running a hybrid MAF/sd setup either. No MAF or 02's. For a NA Setup I would stick with a MAF unless the cam is really big or has allot of overlap.
#33
SD does seem to be a bit more responsive, but the maf does a great job of adjusting for varying conditions.
In the end, the MAF on a MAF tuned vehicle is in full control at wot, it blends with ve at part throttle. It is more of a backup so to speak and not needed, I think it helps make vehicles more versatile in all conditions. It certainly doesn't enchance performance but at the same time, it doesn't hurt performance either on 90% of na vehicles.
As for the blending at lower rpm's, I know the "default" setting for my truck, for MAF only, is 4000 rpm's and I've always wondered why you couldn't raise that number to above your shift points so that you always had a "blend" of VE and MAF? I've never heard of anyone doing it, or read anywhere about it, so I wonder if there's a reason not to? Or if anyone's ever tried it?
Or if I am so far off base with this train of thought that I am nuts? lol
#34
For me it depends on the vehicle. In a boost application if the MAF is maxed out by 4k rpm's I go SD CL. I'm running an EFILive COS 5 SD semi-CL system on my 01 GMC and I love the control and ease of drivability
My Vette I've tried SDOL, SDCL, MAFOL, MAFCL and the best drivability and power came from OLSD on a 416 stroker with a 200 shot and nasty large hyd-roller cam. However now I'm switching it over to a COS3 with SDOL.
