Speedo reading in K/H
Here's a link to the thread I created at the HP Tuners site because I figured it was a tuning based problem.
http://www.hptuners.com/forum/showth...2533#post32533
Pretty much, I threw a tune on it and now it's reading like I'm in kilo per hour.
Guy at the bottom of that link states there is a button that can change this? Am I crazy or is there no button?
DIC = Driver Information Center
Refers to the display in the instrument cluster. If you have the steering wheel controls you can program various functions and view the information and results in the DIC.
I think you need to be thinking about tire size, rear end gearing, transmission selection or gearing or something along those lines. Maybe look for something that calculates final drive ratio. If you change display units from (English/Metric) it does not effect the operation of your speedometer needle. My speedo has scales for both KPM and MPH and the reading does not change when I change the display units. What does change is the information shown in the display in the instrument cluster. For instance it will show distance in miles vs kilometers and fuel economy in mpg vs kpl.
Your problem is not setting your system to read in english or metric units but rather in your settings for tire size, rear end ratio, transmission gearing, speed sensor calibration or something along those lines.
Good luck getting this sorted out.
Check my .bin and let me know if you find anything. It's set as an attachment over at the HP Tuners site, under my thread.
I'd be very suprised if it ending up being something simple because I feel I have checked everything.
You must have changed the tire size and hit the commit button on accident. Your VSS Pulse/Miles & Trans Revolusions/Mile are incorrect also. If you did accidently hit the commit button it will change alot of tranny tables as well. Did you try changing the Tire size back to 28.94 and hitting commit?
Go into speedometer in HPT and hit F1 lots of info in there.
Speedometer Scalars (We do not recommend that you manually adjust these values)
VSS Pulses/Mile: This value is used to calculate the speed value for the engine routines and gauge cluster. It is the number of pulses received from the VSS sensor per mile traveled. If you know your gear, tire and location of your VSS sensor you can calculate this value manually.
VSS Pulses/Rev: This is the number of pulses received from the VSS sensor per output shaft revolution (used to calculate trans output RPM). It is usually equal to the number of teeth on the VSS sensor (depending on the sensor location).
VSS Pulses/Rev - Trans: This is the number of pulses received from the VSS sensor per output shaft revolution (used to calculate trans output RPM). It is usually equal to the number of teeth on the VSS sensor (depending on the sensor location).
Trans Revs/Mile: The number of trans output shaft revolutions per mile. This value is used to calculate the speed that is used for shift and TCC calculations. (A tire sanity check value is provided alongside so you can check the trans tire size calibration against the speedo tire size calibration. This is also useful for troubleshooting accurate speedo but trans shifting strangely issues).
Drive Sprocket Ratio: This is the drive chain/sprocket ratio from the engine to the trans. (eg. for a Pontiac GTP V6 the final drive ratio is 2.93. This is calculated from a diff ratio of 3.29 divided by the drive sprocket ratio of 1.121).
VSS Tire Revs/Dist: The number of tire revolutions per mile or kilometer.
VSS Tire Revs/Dist - Err: The number of tire revolutions per mile or kilometer. Used when a VSS Error is detected.
VSS Tire Revs/Dist - Trans: The number of tire revolutions per mile or kilometer.
VSS Tire Revs/Dist - Trans Error: The number of tire revolutions per mile or kilometer. Used when a VSS Error is detected.
Final Drive Ratio: The final drive (differential) gear ratio.
Final Drive Ratio - VSS Error: The final drive (differential) gear ratio, used when a VSS error is detected..
Final Drive Ratio - Trans: The final drive (differential) gear ratio.
Final Drive Ratio - Trans Error: The final drive (differential) gear ratio, used when a VSS error is detected..
The value is set at 8000 whereas before, it was at 4000.
If anyone would try this, it would be great.
Go to your speedometer.
Find VSS Output Pulses/Mile
Type in any other value than 4000 and then, save the table.
Does your value automatically get locked at 8000 also?
I tried this on a few of my .bins and it happens everytime. WTF?
