Stats on tuning session yesterday
Had my truck tuned yesterday. Mods are in sig.
I am running 7.5lbs (3.25 pulley) of boost with the radix. (other mods in the sig)
I am running a total of 17 degrees of timing.
Intake temps before a run were around 110, and after about 160.
Injector duty cycle is at 89%
Pulling in 56lbs of air
Do any other radix guys have any of there tuning stats? Just want to see how they compare.
If you want I can scan any info you want with mine and let you know. AIT's seem kinda high, When it was 105* outside mine never got higher than 135* I am spraying meth though. I have a huge new heat exchange I will be putting on in a couple of weeks and hop to drop them by another 20*
How do you check for your injector duty cycle? My logging software is AutoEnginuity if that helps
Mark
Mark
Originally Posted by 2004Denali
<snip>....How do you check for your injector duty cycle? My logging software is AutoEnginuity if that helps
Mark
Mark
Not on a dyno. I posted a WOT log from the track
https://www.performancetrucks.net/fo...d.php?t=358385
9psi
20 degrees timing
IAT at 117 after the run
58 lb of air
90% duty cycle
9psi
20 degrees timing
58 lb of air
90% duty cycle
Notorious BIG
9psi
20 degrees timing
58 lb of air
90% duty cycle
9psi
20 degrees timing
58 lb of air
90% duty cycle
are you logging/scanning with hptuners? if so, how do you log IAT's and lb of air? thanks.
TX Tahoe Z71
09-01-2015 09:11 PM
Mossyoakglock
07-17-2015 08:30 AM
