TAC Module
TAC Module
Truck went into reduced engine power last night everytime i cleared the codes and restarted it. Battery power is good and cranks right over. Pulled codes P1516, P1518, and P2108. I checked the connections to the throttle body (was fine), the ground on the back of the pass. side cylinder head (was a little dirty and a little loose so it was tightened and cleaned as much as i could), checked the connections on the TAC module and the pedal. Let it idle for about 20 minutes and drove it around and did some WOT runs and couldn't get the code to come back.
With my wife driving the truck mostly right now so i can't have this kind of stuff happen right now. So hopefully i can get a used throttle body off of here.
My question is though can i use years 02,04-07 classic TAC modules or do i need to find a 2003 only TAC module?
mitchellmade
09-27-2015 08:27 PM
supershift67
09-18-2015 08:21 PM
TAPyvehc93
09-14-2015 01:22 PM
