TBSS intake 90mm TB tuning on 2003 Silverado
no problem. mine would only act up after it was good and hot. but it would cut off at 4500 like a switch. and fwiw my etc scaler was wrong also. it still is cause until i read this post i didn't know what to set it at. all i did was installed the car style tb and all my problems. kind of made me mad cause i wanted to use the truck style for looks. i even made a bracket to put the stock truck intake cover back on. i didn't want anything to stand out other than the 4 bolts holding the tb on.
your math is wrong... Notice the name of the setting "ETC Area Scalar"...
You were just calculating the difference in diameter...
You should be calucating the difference in area.... Which comes out to 24.4%..... OR you could just use this spreadsheet....
http://www.marcintology.com/tuning/TBresizing.xls
Are you running in SD or with MAF?
Actually I am running MAF only in closed loop right now. Eventually when I have time I will get the VE table tuned in and turn it back on, but the MAF is easier to tune.
Let me see if I can find the numbers for Grams/cyl and plot them out. I'm assuming you mean before and after the intake install.
Before the TBSS intake
Code:
Labels 2500 3000 3500 4000 4500 5000 5500 6000 6500 0.662 0.722 0.743 0.765 0.785 0.799 0.803 0.783 0.756
Code:
Labels 2500 3000 3500 4000 4500 5000 5500 6000 6500 0.599 0.649 0.695 0.743 0.765 0.790 0.793 0.761 0.729
Yes but only temporarily...lol
and after.
Code:
Code:
Also if you used a wideband to tune both of those logs, then it looks like the intake actually hurt you... Reason being is that your air mass is lower than before, Airmass = TQ .... Your airmass plot will pretty much resemble your TQ curve...
