TBSS intake 90mm TB tuning on 2003 Silverado
Old 11-05-2009 | 01:24 PM
  #31
jakebdb56's Avatar
Have you tried disabling the P1516 code at all? Just set it to no error reported and no CEL
Back about a year ago I had a P1514 make my truck go into REP in traffic. had to whip out the laptop real quick, clear the code and even disabled it so I could make it home just fine. Never went into REP again after I disabled it, but I eventually made the "proper" calibration for the P1514/P0068 diag tables.
Old 11-05-2009 | 02:19 PM
  #32
truckmann's Avatar
I did end up disabling it at the track and was able to make a few passes without going in to REP. I have it re-enabled now and it doesn't really effect normal driving since it only has shown up at the top of 2nd gear during long WOT runs. I'm hoping I can find out what is causing the issue and fix it instead of disabling the code though.
Old 11-05-2009 | 04:52 PM
  #33
jakebdb56's Avatar
Ah ok, but when you had it disabled it felt alright and didn't ever throw the code?
Old 11-05-2009 | 05:00 PM
  #34
truckmann's Avatar
Yep best I could tell it seemed fine going down the track with the code disabled.
I was able to get all the way down the track anyway without any noticeable issues.
Other than how slow I was ..lol Hopefully I can tune the power back into it.
Old 11-05-2009 | 08:29 PM
  #35
truckmann's Avatar
After checking my ETC Max Predicted MAF Flow table I found that I did not change that table from stock which previously didn't matter I guess since I was running SD. So I upped it 25% and made 3 test runs up to 80 mph without issue. So keeping my fingers crossed that I am just a dumbass and that was causing the problem.
Old 11-05-2009 | 08:33 PM
  #36
BlackGMC's Avatar
Resident Retard
SWEET, hopefully you got it whipped now!
Old 11-05-2009 | 08:56 PM
  #37
truckmann's Avatar
I sure hope so. Thanks again for your help.
Old 11-07-2009 | 05:39 PM
  #38
jakebdb56's Avatar
you're not a dumbass lol. you're smarter than 90% of the LSx enthusiasts our there just because you can tune your own truck. Some people be stoopid, trust me.
Glad you got it figured out, now we need some times/dyno info
Old 11-08-2009 | 12:06 PM
  #39
truckmann's Avatar
Now if i can find the spare time to rework the timing table and get back to the track before it turns cold around here. Wish I could put it on a dyno and do some tuning that way, but my fundage won't allow that.
Old 11-09-2009 | 11:06 AM
  #40
jakebdb56's Avatar
Timing is easy!
Just command 30 degress and you'll be good
