Tech Help**Will these work together, LS7 sprocket, sensor, reluctor converter
I have a shortblock with a 58X reluctor wheel, an LS2 front/rear covers with a front cam sensor part#12591720 and the LS7 cam sprocket is part#12586481
Sprocket/sensor:
I was hoping to upgrade to a double chain but dont know if this will work with my set-up. I don't know if my 2002 Tahoe PCM/Harness will expect a cam sprocket with a 2X or 4x signal. I have the Lingenfelter conversion box for the crank trigger and it also has a harness for the cam sensor.
Will this sensor and sprocket work together?
Do I need to plug in the cam part of the conversion box?
I dont want to put this together and it won't start because I have the wrong sprocket or sensor etc...
Any help is appreciated...
Sprocket/sensor:
BennyB
08-01-2015 08:48 AM
InsaneDomestics
07-27-2015 02:42 PM
