Tech II not able to connect???? WTF?
Custm2500's Rude Friend
Allright, I have tried multiple Tech II's to ensure it's not an equipment issue, I just cant seem to get them to connect to the truck's computer!!! My EFI live V2 connects up and functions perfectly, loggs, DTC's and the like. Any idea's on what I should look to so I can get the Tech II to work? I need to run the ABS bleeding sequence and get rid of this horrid sponge pedal !
I may have inadvertantly locked it the last time I re-programmed my trans parameters. I need to check this. Thanks FastBrick!
Well, just checked the current tune, it's not locked. Adjusted some trans parameters and looked it over to see if there was anything wrong, and found nothing. V2 Flashscan and laptop hooked up to the truck and worked like clockwork. I'm going to have to take it in tomorrow and see if the Tech II will connect to the truck's PCM.
were are you getting the tech 2 from??? Are you 100%sure its functioning properly??? if the cable is damaged internally you won't know and it wont comunicate...
My Tech 2 wont work with the computer for updates or pass through programing... I have to have to put the card in another tech 2 to get the updates.
