Tech II not able to connect???? WTF?
Old 10-25-2009, 03:26 PM
454SuperSport's Avatar
you running a custom operating system? load a stock tune back in it and try the tech2 again.
Old 10-26-2009, 06:40 AM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by ForcedTQ
Allright, I have tried multiple Tech II's to ensure it's not an equipment issue, I just cant seem to get them to connect to the truck's computer!!! My EFI live V2 connects up and functions perfectly, loggs, DTC's and the like. Any idea's on what I should look to so I can get the Tech II to work? I need to run the ABS bleeding sequence and get rid of this horrid sponge pedal !
Is your tune Locked??? That may be why the Tech2 won't finish conecting to complete the procedure.
Old 10-27-2009, 12:39 AM
ForcedTQ's Avatar
Thumbs up
Not that I have messed with, you're refering to a MAF-less SD tune?
I may have inadvertantly locked it the last time I re-programmed my trans parameters. I need to check this. Thanks FastBrick!
Old 10-27-2009, 12:42 AM
1FastBrick's Avatar
No problem I have heard if there locked you can not comunicate with them with something like a tech2. Never had the oppertunity to try it though.
Old 01-31-2010, 09:08 PM
ForcedTQ's Avatar
Unhappy
Well, just checked the current tune, it's not locked. Adjusted some trans parameters and looked it over to see if there was anything wrong, and found nothing. V2 Flashscan and laptop hooked up to the truck and worked like clockwork. I'm going to have to take it in tomorrow and see if the Tech II will connect to the truck's PCM.
Old 01-31-2010, 09:18 PM
1FastBrick's Avatar
were are you getting the tech 2 from??? Are you 100%sure its functioning properly??? if the cable is damaged internally you won't know and it wont comunicate...
My Tech 2 wont work with the computer for updates or pass through programing... I have to have to put the card in another tech 2 to get the updates.
Old 01-31-2010, 11:32 PM
ForcedTQ's Avatar
Thumbs up
My local community college Automotive program. They have 6 of them I believe, so I will be sure to try as many as I can. I will take a close look to find one of the best looking units physically, as I know the students can be hard on the equipment. As far as it functioning 100% correctly, I am not sure. I do know the unit gets power, as I can navigate the menus, but when I try to perform a function that requires the Tech II to access the PCM, I get a connection error message. Thanks FastBrick!
1989k1500
11-02-2015 05:16 AM
Wrecker 426
09-29-2015 11:00 PM
1989k1500
09-29-2015 10:53 AM
brandon6.0
09-25-2015 11:58 PM
Quick Reply: Tech II not able to connect???? WTF?
