Throtte Body Gremlins...!~@#$%^&*
Old 09-09-2011, 04:35 PM
  #91
FormerVendor
CalEditor@PCMCalibrators's Avatar
You can see how the circuits are paired up
LS2
VS
2003 5.3L Truck
Old 09-09-2011, 04:39 PM
  #92
FormerVendor
B & D are just grounds and could be tied together just like the LS2
H & E are both 5 volt wires and they may have the same driver or they may not, but all you need is one of the two
Then you are down to your 6 wires like the LS2
Hmmmmmm I wounder what the X link does?
Old 09-09-2011, 04:56 PM
  #93
EVILGMC's Avatar
5.3 and ls2 have opposite signals....need to use a vette TAC to do a simple re-pin and you dont get the full blade travel IIRC.
Old 09-09-2011, 04:59 PM
  #94
FormerVendor
Take a look at the Circuit ID numbers
Old 09-09-2011, 06:26 PM
  #95
EVILGMC's Avatar
when i first switched to a 90mm, i used the speartech harness (8-6pin) and a corvette TAC...it worked, but not 100% throttle opening.
the diagrams do seem to indicate a simple re-pin would do the trick. not sure about motor direction vs signal in each TB though.
Old 09-09-2011, 07:12 PM
  #96
FormerVendor
I would do it by circuit number rather than pin location or even + & -
The circuit numbers are really the way engineering looks at them
Old 09-09-2011, 07:32 PM
  #97
DrX
DrX's Avatar
The TPS signals need to be moving in the same direction, rather than opposite directions as with the LS2, LS3 and 87mm truck TBs.
Old 09-09-2011, 07:39 PM
  #98
FormerVendor
Have you ever had one open?
We are in the process of purchasing TPS's for them.
How many used T-Bodies do you have or have tossed in the last 5 years?
I see that you are a GM tech. You should have a few.
Old 09-09-2011, 08:14 PM
  #99
DrX
DrX's Avatar
Not a tech but have come across quite a few bad TB's. I have had these open and have even modified the sensor boards.
Old 09-09-2011, 08:21 PM
  #100
FormerVendor
My bad, but you have a GMIN correct?
Quick Reply: Throtte Body Gremlins...!~@#$%^&*
