Throtte Body Gremlins...!~@#$%^&*
Old 09-06-2011, 10:02 PM
  #41
EVILGMC's Avatar
the 8.1 TAC, TB and pedal were my donors...did some research and the parts lined up
yes, 5vdc at the reference wires with TB unplugged and key run
Old 09-06-2011, 10:26 PM
  #42
EVILGMC's Avatar
Looking to get a new PCM ASAP
Old 09-07-2011, 01:05 AM
  #43
SLOXCAB's Avatar
Originally Posted by Dezert1500
All I know is my LS3/90MM works flawless. It's all about the N/A stock 4L60E, 10bolt power combo! It's the damn heat pump paper weight you've got messin' things up
Classic!!!
Old 09-07-2011, 10:28 AM
  #44
FormerVendor
CalEditor@PCMCalibrators's Avatar
Is the cover on the Throttle Body riveted or clipped on?
Have you tried pulling the terminals from both the T-Body connector and the TAC modlue and soldering the crimps? I have found this to fix about 40% of the 5% that replacing the T-Body didn't fix. The other 60% of the 5% I rewire and solder the crimps
95% of the time a new Throttle body fixes the issue if DTC P2135 is set
The other 5% is a wiring issue. I end up rewiring the TPS and TAC Motor circuits about 6 out of every 10, but first I try soldering the crimps and it works 4 out of the 10. It takes me 10 minute to solder the crimps and then I am off on my test drive. If it doesn't fix it I am only down 20 minutes vs an hour and a half to restring wires crimp new ends on and the test drive.
I had 1 bad TAC module in the last 12 years. That was way back in 2002 and that was on a 8.1L Avalanche.
Old 09-07-2011, 10:44 AM
  #45
EVILGMC's Avatar
response in red
the LS2 has the security screws. the 87 has clips iirc
i have not tried soldering them. i have removed 6" from the TB end of the harness and re-pinned it.
i have tried 87 and 90mm TBs...both set codes. when i plug in a 78mm, the codes clear at key run but i cant start it due to the blower TB flange and the shortened harness wont reach.
i have tried swapping TAC and pedal with no luck
Old 09-07-2011, 11:12 AM
  #46
FormerVendor
About 6 months ago I had an Escalade that came in with a P2135. I sold a new GM T-body, but the T-Body that was on it had been replaced 6 months before that and it had a New GM Wire Connector with wires on the T-Body also. I installed the T-Body and the guy came back about 4 months later with the same concern, but different DTC's and no P2135. I could not duplicate the DTC's so I soldered the crimps and shipped it back out. The guy returned 2 days later and now P2135 was the only DTC set.
I load tested the circuits by installing a headlamp bulb on each circuit and checking for a voltage drop. I also did this in paired circuits and found no differences in any of the circuits while wiggling and pulling on the harness and terminals. -- I sent the guy back out and he returned on the following Monday. I had enough and I rewired the circuits. I thhave not seen the guy in 2 months. Now was it a bad wire or was it the REPLACEMENT GM wire connector?
Old 09-07-2011, 11:14 AM
  #47
FormerVendor
The TPS is not wired to the PCM and that is why you can't see the TPS 1 and TPS 2. The TAC sends the TPS data to the PCM via a UART serial data.
I can't see a bad PCM setting these DTC's, but I will sell you a PCM
Old 09-07-2011, 11:43 AM
  #48
EVILGMC's Avatar
I reused the TB connector...I bought pins and recrimped with the proper tool.
I am 90% ready to do a DBC swap....too bad the 90+mm cable TBs are $$$$
codes are still P2135, P0120, P0220, P1515, P1518
Old 09-07-2011, 11:48 AM
  #49
FormerVendor
Can you send me a copy of your tune and a picture of the T-body?
Old 09-07-2011, 12:01 PM
  #50
EVILGMC's Avatar
emailed my tuner for the latest file. that is the LS2 (silver blade version) I have also tried an 87mm NNBS truck TB
Quick Reply: Throtte Body Gremlins...!~@#$%^&*
