timing advance with turbo?
HP Tuners | EFILive | Hand Held Programmers | Stand Alone PCM's | Electronics | Wiring Diagrams
03-10-2008, 10:33 AM
t_thall
how much timing are you guys running on the 5.3 turbo'ed? my engine is still stock and i want to run 10psi
Like
t_thall
Find More Posts by t_thall
03-10-2008, 10:54 AM
zippy
With cool enough IAT's I'd think you shouldn't have a problem with 18º to 21º.
Like
zippy
Find More Posts by zippy
03-10-2008, 10:58 AM
Stoichiometric
I run 17.5 degrees at ~10 psi. Start low and work your way up, you do not want any detonation at 10 psi.
Like
Stoichiometric
Find More Posts by Stoichiometric
03-13-2008, 11:07 AM
t_thall
ok thanks
Like
t_thall
Wheel/Tire Suggestion on a Budget 2000 Sleeper Silverado
BoostedBowTie
06:46 PM
PCV setup and Vacuum source setup
mhorn0817
07-08-2017
01:54 AM
FS: Duramax swapped RCSB 1500 4x4
thunder550
04:53 PM
Multiple questions about my setup, any input appreciated
GMCtrk
07-17-2015
06:39 PM
4.8 turbo, looking for ideas
Cowboy17
08:22 PM
Tags
10psi
53
advance
advanced
cam
forums
ls1
ls1tech
tech
timimg
timing
turbo
turbocharger
turbos
Back to Subforum
View Next Unread
w/b help
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
08:29 AM
