Tips for Dynoing
Old 11-20-2005, 10:40 PM
YenkoST's Avatar
Hey man,
Thanks for you help...naw these guys didn't scare me off. I went and started the run and but I didn't get to complete a full pull, air/fuel went from 12:1 and jump straight up to 15:1 at 4000 rpms so we unstrapped it and i will try to find someone with a tuner for the thirdgen camaro(TPI) engines. Any, we let off at 4000 and it made 246rwhp. Peak is supposed to be at 5500 but with the air/fuel reading like it was, I wasn't about to push it. So, I will have to get the torque graph for him...right before I went, a truck broke so they were a little scattered when it was my turn so I will see what it shows for torque. I am disappointed a little b/c of the air/fuel but this is what dynos is for....tuning it up. Maybe I will have some real number soon....should be around 320-340rwhp once its all said and done at peak.
Old 11-20-2005, 10:59 PM
YenkoST's Avatar
Oh, this was with the converter unlocked, in 3rd gear, around 65-70 degrees, and slight shower.
Old 11-21-2005, 02:55 AM
GMC_DUDE's Avatar
Sorry to hear about the aborted dyno run. Ive heard of lean cruise before but lean acceleration??? ...um...no. You were wise to do what you did. Please keep in touch and let us know how it goes after the recal.
edit: Also meant to say it sounds like you are doing everything right.
Old 11-21-2005, 10:18 AM
kbracing96's Avatar
Originally Posted by GMC_DUDE
Have the operator either dyno it in 2nd gear, or if they refuse, then in 3rd gear. The fewer shifts the better.
I don't understand why you would say this^^. The only reason for dynoing in 2nd is if you would be hitting the speed limiter in 3rd before hitting redline. Running the trans in second will produce more drive train loss as you are turning an extra set of gears. When your in 3rd, your 1:1 and the power is going strait though the trans with minimal loss.
Old 11-21-2005, 10:21 AM
YenkoST's Avatar
Yea, I check all the fuilds once again before the truck went on there so, glad nothing broke. Can't wait to get this thing back to 13:1 roughly and see the numbers....should be pretty good!!
Numbers were not corrected as well!!
$A_Money$81
03-27-2023 10:25 AM
Miguel199
10-16-2015 08:04 PM
Lthompson
10-02-2015 12:45 AM
jscherbs
09-30-2015 07:54 AM
97_ek
09-23-2015 09:16 PM
Quick Reply: Tips for Dynoing
