Trans Brake/2 Step/Smooth Stage Wiring
Hey guys I've done some searching and mostly just find generic wiring diagrams but I was wondering if anyone has wired anything similar. I've read alot of other build threads on other forums where guys are wiring in relays and in line fuses when they wire in their trans brake/ 2 Step/ Bump Box. I've included the wiring diagram for both the Snooth Stage(bump box)/ and 2 Step and neither one mention fuses or relays. Just wondered if anyone has done anything similar. I'm hoping it's as straight forward as it looks I hate wiring lol
Yea I decided to do the same, I called and asked if they recommended any type of relays or fuses and was told no. I actually started wiring everything tonight but I'm waiting for some paint to dry, ended up turning the old temp controller into a blank to mount the smooth stage so once that's all dry tomorrow Ill finish up all the plugs and wiring and get some pictures up.
Everything is all wired up just need to get it on the ground and test it out didn't end up finishing till almost 1am. I want to call ATI tomorrow morning though, when I tested the transbrake with the truck off it's very hard to hear. I'm used to nitrous solenoids that are fairly loud, I can hear this one it's just seems abnormally quiet. Its an ATI Compu-Flow valve body so the solenoid is internal so that could be a contributing factor. It also only draws one also.
I haven't wired them up yet, my shifter only came with a neutral safety switch, I need another micro switch to get the reverse wired. But yeah since I had a 12v key on from the HVAC Controller I used it to power a junction block for the multiple things that require key on power. Shouldn't be very hard at all
CHEVY6000VHO
10-21-2005 01:34 PM
