Truck will not stay running!!
Ok so heres the deal. Everything on my truck is new. I purchased a mail order tune from Nelson and it should be good to 5-7 psi. I only bought mail tune so that I could fire it up here at the house and have all the bugs worked out, that way when I take it to Nelson for the SD tune everything should be working ok. I just fired up my motor last night for the first time and it seemed to idle just fine. This morning i figured I'd let it idle for a couple mins to let it get to temp and see if the E-fans were working ok. Seems like it turns on fine, idles great for about 10 seconds and then starts shaking, sputters and dies!! I put in new o2 sensors,fired it up and it still dies. Also i can rev the motor just a tad and it tries to stay on but ends up turning off. Do you guys think there could be something wrong with the tune?? Security relearn?? If that was the case it wouldnt even turn on correct?What do you guys think would cause this?? Heres a quick vid. I have p1336 and the code for the evap coming on. Other then that nothing else seems to be wrong. Hope you guys can help. Thanks
VIC
[/[/QUOTE]
VIC
[/[/QUOTE]
GreyChevy
07-07-2015 08:57 PM
