The Tune File Thread?
Not sure if we have had one in the past.
I am far from a good tuner, and I'm always looking to learn. I'm well aware that no two trucks should have the same tune, although it would be nice to see how people's tune files compare.
Do we have such a thread where you can compare tunes? I realize there is the HoldenCrazy website for EFI Live, but it is dated and there are only 2 or 3 modified Silverado tunes.
I figured this wouldn't be too bad of an idea as long as people realize that tunes from other people's vehicles should be observed and not copied.
Maybe use something like Rapidshare to upload the tuning files and then add in a bit of information about each truck?
It's just a thought, if it's flawed, then by all means let me know.
I agree, but like anything there is good information and there is poor information. Being able to decipher between the two is the tricky part. I think it would be interesting to see what other people's tunes look like. At the very least, maybe someone might point out some issues with my tune.
Resident Retard
Ok, Bill said we should go ahead with this idea and create a sticky.. So lets start gathering some info... The first post in the sticky could be an ever growing post that will have a small detail but linked to the users post which contain the entire mod list and tune. So please post up what yall think the Mod List Template should include. It should be similar to the FTL mod template but a little be more detailed.
engine combo
na or fi and how much boost
rear gear and tire size
stall size
octane
what deleted out of the tune
sd or not
there would have to be a good size list I would think to each tune and you would have to make sure not to forget anything about your setup. just thinkin about mine I dont have that much dont to the truck but when you factor in tuning it it does.
stall size
octane
sd or not
Resident Retard
Ok so can yall think of anything else to be added?
Mod List
Year:
Make/Model:
Orginal OS#:
Custom OS#:
Closed Loop/Open Loop:
MAF/SD:
Injectors:
Segment Swap (Engine, Transmission, etc):
Transmission Pressures:
Deleted (O2s, Evap, TM, Misfires, etc.):
Engine displacement:
Heads:
Cam:
Intake/CAI:
Maniflold:
Headers:
Exhaust:
Octane:
Transmission:
Torque Converter:
Gear Ratio:
Tire Size:
Know Issues (idle problems when hot, KR, etc)
Mod List
Year:
Make/Model:
Orginal OS#:
Custom OS#:
MAF/SD:
Injectors:
Heads:
Cam:
Intake/CAI:
Maniflold:
Headers:
Exhaust:
Octane:
Transmission:
Torque Converter:
Gear Ratio:
Tire Size:
