Tuning for a 100 shot
Old 10-18-2011, 12:59 PM
TOTM: January 2007
Last Call's Avatar
Default Tuning for a 100 shot
Going to the track tomorrow to see what the 5.3 will run with a 100 shot. All stock, to the intake and muffler.
I was thinking pulling 4 degrees from high octane table and pasting into the low octane table so they are the same, changing the TPS precentage for power enrichment, removing torque management, zeroing out shift times, and adding a couple mph and rpm's to the shift points.
Anything else you would do?
Old 10-18-2011, 01:26 PM
Baltimore Whore
Mangled03gmc's Avatar
Don't change anything.. Pull some Tq management.. Add some to the shift points and such..
Old 10-18-2011, 01:47 PM
slowec's Avatar
If you are on the stock timing table. Pull nothing!
Changing the tps % won't help, you'll be at over stock percentages anyhow.
remove TM without even a servo = not good
zero shift times... maybe .250
add a couple rpm's to the shift points, why not. Just make sure to raise the in gear rev limit plenty above your shift points so not to hit the limiter on the jug.
These are just my two pennies...
Old 10-18-2011, 01:54 PM
Former Vendor
Nitrous Express's Avatar
what is your overall timing @ WOT?
if you bump up the shifts make sure not to hit the rev limiter!
Old 10-18-2011, 02:35 PM
9 Second Club
Rhino79's Avatar
Is this a dry or wet kit? I agree with the others, leave timing clean up the trans tune and shift points, and be sure to change out the stock plugs.
Old 10-18-2011, 05:44 PM
GFYS and STFU
Spoolin's Avatar
Yeah Wet or Dry? I'm assuming wet. Are you trying to blow this motor up before putting the 6.0L in there? Henry going out there with ya?
Old 10-18-2011, 10:17 PM
TOTM: January 2007
Last Call's Avatar
Thanks for the help everyone... It is an NX wet kit. I am going to remove 2 degrees from the high octane table and see how it runs. Not going to do anything with torque management, reduce the shift times to .250 like slowec said, and let her rip.
Got the nitrous kit installed... Couldnt even feel the 50, so I went to a 100 and it felt better, but not great. Bottle pressure was low, so will get it refilled tomorrow.
Just trying to beat my brother-in-law with his mildly modded Lightning. Then I am going to swap in the 6.0, blower, 4l80, etc.
Old 10-18-2011, 10:36 PM
9 Second Club
Rhino79's Avatar
Man that 2 * would help it...the stock timing is plenty low to handle it. Hell you could spray 125 on the stock table with the fuel right.
Old 10-18-2011, 10:38 PM
2007chevy5.3l's Avatar
Im hitting mine with the 100 and im running 25* timing while spraying and have no knock retard. Do you have a wideband? Make sure fuel is in check, spary it while logging and see if all is good...
Old 10-19-2011, 04:17 AM
slowec's Avatar
There is no reason not to hit it with the 150! Run 1000 psi bottle pressure and the 150 pills and hush up the in law. The nx kit will be a lil sluggish. If you can log knock, subtract 2 off the fuel jet and try some quick blast . Like if your kit is calling for a 38 fuel, try a 36. Those nx kits are real fat tuned. make sure to get colder plugs. I like ngk br6ef gapped at 32. Have fun, you only live once.
Quick Reply: Tuning for a 100 shot
