Tuning for Boost in the IAT and ECT correction tables....Zippy inside.
High on diesel fumes
Originally Posted by KySilverado
I guess my take on it is that I am tuning for the street. It is a daily driven street truck. Don't really give a hoot for consistancy at the track. I go there once in a while to see If I have made any improvements. I'm not a bracket racer. When I go to the track I let it sit and cool down in hopes of running that one better time. It is a modifer table. Add more timing when the IAT's are cool, take them away when they are hot.
My 2 cents. Makes perfect sense to me to use this table.
![Werd](https://www.performancetrucks.net/forums/images/smilies2/werd.gif)
My example was for the track, but the same applies for a daily street-driven truck.
Moderately Differentiated
Originally Posted by jephs422
So is what your saying is that you can see better 60 foot times by tuning your IAT table rather than just commanding the correct timing? I do understand that on the street it makes a lot of sense, but I don't see how you can have any gain at the track. If you know what timing will net you the best times, why not just run that? The only thing I can think of where it would make sense, is if you were running all day long, and you optimized your tune for the first run when you were nice and cool, but after that you need some timing retard later in the day due to the heat. But that sure does leave for inconsistancies, as well as lower e.t's. But if one is too lazy to just change out his tune, I guess it would work.
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
jephs, your statement/questions doesn't seem to take into account what thunder is preaching. Ky...(hehehe I said KY) is the simplest but shortest explanation. In short, using the correction table, I am doing what you are suggesting in bold in your statement. The problem is that particular timing is with the restraints of heat included. You are leaving power on the table in the launch. Inconsistency will be taken care of with a "TUNED" correction table. I hope no one is just suggesting to throw any spark in this table anywhere. You are thinking this correction table only as retarding. Add timing before 98*IAT. Take away timing at 113*IAT and up. Or address it however works best for your application and location.
If it's too hot, then fine you aren't awarded the max timing in the table. If it's colder, then you get bonus timing....no tune changes.
What's so inconsistent about using it. Having a spark table tuned to run with what your high IAT is? What fun is that? This way in my tune, I am attempting to run the best timing to net me the best times...street mostly, but track as well. I am just tryng to take advantage of cooler temps down low when I have them.
Former Moderator :(
Ok I am only going to speak for MagnaCharger on this one. On a Magna Charged vehicle please do not attempt to do any IAT timing for any reason or engine damage could occur The IAT sensor on a Magna Charger is only there for safety purposes and SHOULD NOT be used for any performance tuning, the sensor is in the manifold and is very subject to reading radiant heat off the manifold and not of the true IAT itself and the sample rate and update rate is slower than most other sensors in the data stream so using it for any other reason other than it was designed for is not suggested and could cause engine damage due to detonation . Many hours of testing has proven that at 160 IAT the fuel starts to dissipate and the engine starts to go lean so keeping your IAT's under 160 is a big + but on A magna Charged vehicle changing the timing at 105 degrees and 125 degrees will net nothing in the way of HP our chassis dyno and engine dyno has proven this time after time. Using IAT timing in a Non supercharged application can net great results if the IAT sensor is in the MAF and proper tuning is applied. Like I said I am speaking for Magna Charged vehicles only and no other.
After the way the last posting went I considered keeping out of this one, but I'll add a bit to it. Somehow there is a misconception that there is timing being added when the blower is warm. From 104 degrees and up there is timing pulled and not added. For those that have already seen some of my IAT work you can see that it goes right along with what Crash Dummy posted that adding timing at 105 degreeds isn't going to gain anything. This isn't just a saftey reason, this is because the Radix being the heat pump that it is you'll lose power if you don't start pulling timing around that point. The point where adding timing comes in is around 86 degrees of IAT and colder. If you run logs on a Radix truck you'll find that you are only under 100 degrees for about the first 100 feet. The question of why not just put the timing where you want it in the first place is that you aren't going to be able to run the same amount of timing at say 80 degrees of intake temperature as you are 120 which if you're running a smaller pulley is around mid track. This is the day of high tech tuning. Trying to tune an engine that runs such a wide basis of air temperature with one specific number sounds like something you'd do with an older vehicle with a distributor or something that is tuned only on a dyno where you are only wide open for a few seconds. Tuning a radix to run it's best numbers pretty much commands that you have to compensate for the impressive amounts of heat that the Radix makes from start to finish. I also pull timing a bit sooner in the ECT table than the Radix tune comes with. I've found that if you are running a fairly agressive base timing table that you will run into some spark knock conditions (sometimes audible and yet not picked up by the sensors) at around 190+ degrees. I add timing for the engine if it is cooler than 167 degrees since we all know that this is the reason we spend so much time trying to cool the engine in the staging lanes and pits. A cooler engine will take another degree or so of timing without knock. The other thing this takes care of is that it allows the customer to run the stock thermostat in colder temperatures if he'd like and the pcm will pull a degree of timing out verses when he's running the 160 stat and not have to change the programming of the pcm. With today's technology I don't see why there would be a reason to not take advantage of the extra tables.
I think the waters have become a bit muddy'd here so let me throw my 2 cents in and mix it up a litle more:
On a TRACK ONLY tune I would tune WITHOUT the IAT's (zeroing the IAT table), using only the high/low octane tables for consistency....this is THE ONLY WAY you can guarantee consistency in your tune and can attribute changes in et/mph to temps, trach condition, mods, etc. "taking advantage" of the extra tables will net you nothing more than having one more variable in your setup....and we all know that the best drag racers keep it simple and efficient. I think logging IAT's when drag racing is agreat idea though...it'll help you nail down your timing tables so that you won't have to rely on a timing table adjustment
On a street tune I would 100% use the IAT table, it's there for protection of the engine and should be used as such....but ONLY as such. I think that trying to use the IAT tables any other way is asking for trouble....the sensor doesn't update fast enough to be of REAL use in performance tuning and relying on it is just askig for problems
LS1Tech Sponsor
I take it you have not been to the track many times fast vehicles. lol. Its no were near simple and there is many variables in tunes from day to day, track to track and temp to temp. No sense arguing with people tuning double didigit ET vehicles...............I guess.
As for not knowing my ****...hmm, let's see. OK, go ahead and tune with the IAT table and see where it gets you, the IAT sensor is about as accurate as the stock narrowband 02 sensors and we ALL know how accurate those are right
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
And remember...it's ALOT easier to run 10's in an S-10 than it is in a 5600lb full-size.....
what a rush!
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
https://www.performancetrucks.net/fo...12#post3372812
Originally Posted by moregrip
He can argue with himself if he wants....I talk to myself
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
