tuning makes the truck idle bad
Old 11-13-2008, 05:52 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Originally Posted by RandomHero
I'm sorry, but you have terrible grammar.
Learn to spell old man, your hands are playing tricks on you
Random...the freaking literary critic let me see what I can do to get that title fixed for ya
Old 11-13-2008, 06:06 PM
RandomHero's Avatar
Tech Junkie will work just fine I promise
Old 11-18-2008, 09:14 AM
Biggin's Avatar
ok ******** my truck is fucked up i didnt ask 4 ur comments on my grammar i really dont know all the stuff the guy did that tuned my truck but its not the tune EVER time u hook up any kind of software it dont matter if u take the tune off the idle will drop and the battrey gage will drop and the truck wont run... No one around where i live konws whats wrong with it and for the next posts if u dont have any useful info about my tuck dont reply.
Old 11-18-2008, 09:24 AM
trever1t's Avatar
Listen up here...your original post is vague and not clear. You were offered a few suggestions but how can anyone help you with the limited information you have provided? I still don't understand what the problem is.
There is no reason to start using bad language or call names. Can you please try to describe in detail, step by step what is occuring? What Who's tuning and exactly what changes are being made? Can you post your tune here for us to look at?
Old 11-18-2008, 11:05 AM
Moderately Differentiated
dewmanshu's Avatar
So...
oookaaay, that's bold to say. But I'd go to agree it doesn't sound tune related.
EVER time u hook up any kind of software it doesn't matter if u take the tune off
I don't understand what you mean by "take the tune off". In HPTuners, are you doing a "Full Write", like 2 minutes and so many seconds? Or a quick flash, like 30 seconds? The 2 minute one will screw your idle up for a bit most times unless you have dead nuts idle tables. The quick flash isn't so bad, but you will get stumbling and what not. Voltage can obviously bounce around as it is trying to idle.
I have found, you need to key cycle at least one time no matter what for things to be sorta normal. But you shouldn't see the problems you speak of. Does it eventually go away? How long before it does (if it does)? Your voltage issue, does it drop while running? Your injectors have a voltage offset table, if you are having wacky idling issues and voltage issues at the same time...you gotta attack that voltage problem first. You have stock injectors? Stock injector tables?
Gotta sort out the voltage problem first. I forgot to look at your sig, what year truck? The alternator should have a regulator built into it, the tune should not affect the voltage. But the voltage WILL affect the tune (idling).
Old 11-18-2008, 12:57 PM
Resident Retard
BlackGMC's Avatar
I would log your O2 sensors and see if they are working properly, you don't have a cam so I don't think your problem is in the tune, i think you have a sensor that is toast cause the tune to mess up... That is just my .02....
Old 11-18-2008, 12:58 PM
Resident Retard
BlackGMC's Avatar
Better yet, post up a log of it!
Slammed96
07-27-2015 07:22 AM
black6spdz
07-16-2015 01:32 AM
hackrst
07-11-2015 11:17 AM
GreyChevy
07-07-2015 08:57 PM
Mzay
07-06-2015 11:03 PM
Quick Reply: tuning makes the truck idle bad
