tuning shift points
Hello Dave
Your problem is your part throttle shift speeds, both the shift tables as well as the Part Throttle WOT shift value. They are way too high for your desired shift RPM. Bring them down a good 5% and you should be sitting better.
The rpm for each gear displayed at the bottom of the screen won't be accurate for first and second gear. Your torque converter is unlocked, so there will be a decent amount of slip, even at that high of an rpm, which is causing you to not meet the MPH condition of the shift.
