tunning for injectors
My current tune on my 02 is for 44# truck injectors if I swap to the car style 42# injectors will in need to retune?
not sure I have not ordered the other injectors, Im am tring to sell the 8.1 marine injectors first. The ones I was looking at were the racetronix 42# and it does not say what bar on thunders website
How do I change this text
Part Number 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
All tests run with n-Heptane @ 20oC (+/-1oC), 3.0 Bar (+/-0.01 Bar), 14VDC (+/-0.05VDC), saturated driver with RC cutoff
Static Flow Rate: 42.29 lb/hr (+/-4%)
Dynamic Flow @ 2.5ms PW @ 100Hz: 9.96 mg/pulse (+/-6%)
Coil Resistance: 15.9 Ohms (+/-0.35 Ohms) (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Spray Pattern: Tri-Cone
Physical Dimensions: EV1 Body Type
Connector: Minitimer (Bosch EV1)
Factory fitted with Viton upper and lower o-rings.
Grease supplied to lubricate o-rings prior to installation.
Brands: Delphi
Manufacturers: Delphi Injectors
Model 17113739
Categories: High Impedance
Retail P/N: 135-INJ-17113739-8
Manufacturer P/N: 17113739
Static Flow lb/hr: 37.95
Static Flow cc/min: 398
Dynamic Flow (mg/pulse): .748
Dynamic Flow Tolerance /-%: 5%
Connector Type: Multec 2 (Delphi)
Weight (non-shipping): .05 lbs
Model 17113739
sense you guys are talking about injectors. through a tune can you apply more fuel? "stock"
my truck already has a tune in it and im thinking i could have my tuner apply more fuel,through out the whole rpm range.
thanks
Ed
thanks
Ed
