V2 to LC1 issue
Ok, so.. Figured out the problem. Me and a friend went thru the entire wiring to see if maybe a ground was off or something wasnt right.. Turned out to be that the LC1 readout in the efilive was reading in Lambda. Had to hook up the Innovate LM software and go thur the process of changing that and resetting the LC1 interface. After doing all that I hooked up the serial cable to my V2 and it worked, AFR was all correct. So if anyone else has this problem, its in the LM software and you have to change the settings. Pretty simple
murderedSS
27
10-12-2015 11:13 AM
TAPyvehc93
09-14-2015 01:22 PM
