Vortec Max Tuning
Is there anybody that has a good tune for a 06 vortec max or that can help me out, I just got Hp Tuners and started working with it. Any help will be appriciated. Also what wide band would be recomended? Truck in sig.
I have been messing aroud with some stuff. I cant seem to be able to get my o2s to read correctly at wot, sometimes 230 mv and then next cell it will jump to 890. I tried and have been adding to pe table but doesnt seem to help. Any ideas.
Hello Dave
Check your PE enrichment delay first off. If it is anything other than 0.0, change it. Report back.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by dc_justin
230mv at WOT is not good. 890mv for N/A is good.
Check your PE enrichment delay first off. If it is anything other than 0.0, change it. Report back.![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Just tdo the math and set your PE to about 12.6 a/f, to be safe until you get a wide band. But, I dont think you really need one yet, unless you have bigger plans for it other than intake and exaust.
Other than that, adjust your fuel trims, add some timing, mabye play with dwell if you like to live dangerously, raise you shift points, adjust pressures, get rid of torque managment( you have a warranty), raise your rev limit remove traction control, raise your speed limiter, if it starts to idle a little wierd, raise your running airflow a little (10-20%). Make sure you saved your stock program!!!
And finally RESAERCH RESEARCH RESEARCH!!! there is a **** ton of info on how to do this stuff so keep reading and you will start to get the hang of it.
Moderately Differentiated
have you screwed with you pe enable settings yet? (highly advise to do what dc_justin says on the pe rate)maybe you made it hard to get into pe and it isn't reacting for you because you aren't telling it to. Hard to help you with out a tune and scan posted up.
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
research research research is right, but we'll still help you along.
ps, did i mention to post up your tune and scan yet?
I always like to keep it between 890 and 905, but for some reason it is not responding. I keep on adding to PE value but no change. I havent had time to mess with here latley and i am waiting for my wide band. What else could it be? I am just confused that the cells jump around that much, and the only mod is the exhaust.
What did you use to lower it?
