Weird Idle AFR problem
Old 10-09-2007 | 07:12 PM
BlackGMC's Avatar
Resident Retard
Default Weird Idle AFR problem
Well ever since I did my last round of AutoVE tuning my AFR has been acting up. It happens mainly at first startup, coming to a stop or after driving and putting it into park. The AFR will go rich for some reason, like 12.5-13.1 and stay there for about 30secs-1.5 minutes, then it goes back to normal.... It has thrown a bank 1 and 2 rich Engine code. I just trired lowering the VE table in the Idle MAP ranges (30-40) by .95 and it seemed to help a little bit.
Any help will be appreciated. Do you think it will work it self out, I mean do you think the STFT and LTFT are just taking a little while to learn?
Thanks in advance.
Old 10-10-2007 | 03:48 AM
01Blackerado's Avatar
You should post up your tune. It might be something in the park to drive enrichments. Can't really tell ya without seeing the tune honestly though. A log file of the run would be nice too. Hopefully its something easy and not mechanical
Old 10-10-2007 | 08:47 AM
BlackGMC's Avatar
Resident Retard
Well I messed with it some more last night after reading a couple of thread and I lowered the (400-800, 30-40) cells about 10% after comparing them to the stock file and it seemed to help. I will post up a tune later on today during lunch.
It better not be anyting mechanical, the truck on has 38k on it and it is basically stock.
Idryfly5
09-02-2022 09:55 PM
mikeyjm1
17
10-30-2015 12:04 AM
SlvrSierra4.8
10-01-2015 10:39 PM
Pimpinpete
09-08-2015 08:39 PM
custm2500
09-08-2015 06:53 PM
