what codes are these?
Old 05-14-2007 | 09:16 PM
Phantom's Avatar
11 Second Club
i use a ground as well to "fire" the solenoid...what do you mean the the relay need nitrous running through it?
Old 05-14-2007 | 09:21 PM
dewmanshu's Avatar
Moderately Differentiated
i meant solenoid. if the relay coil is pulling when the truck was off and solenoid was "firing" when the nitrous was off, it will overheat and shorten it's ife drastically.
Old 05-14-2007 | 09:27 PM
Phantom's Avatar
11 Second Club
well my solenoids are prolly fucked then...one of these days i'll finish installing that stuff and find out
Old 05-14-2007 | 09:43 PM
CHEVRACER83's Avatar
GM HAS HAD ALOT OF PROBLEMS WITH FAILING BATTERY TERMINALS IN THE NEW TRUCKS...
MAY BE WORTH YOUR TIME TO TAKE THEM BOTH OFF AND CHECK THE THREADS ON THE CABLE AND THE BATTERY TOO.... BECAUSE SOMETIMES THE TERMINAL YOU SCREWQ ONTO WILL ACTUALLY START TO BREAK OFF...
EITHER WAY TAKE IT INTO THE DEALER, AND TELL THEM YOU ARE HAVING INTERMITTENT BATTERY PROBLEMS, AND THAT YOU HEARD THERE WAS A BULLETIN OUT ON IT.... THEY WILL CHECK IT OUT..
HERES THE BULLETIN
Subject: Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt) #02-06-04-015A - (03/07/2006)
Models: 2001-2007 GM Passenger Cars and Light-Duty Trucks (Including Saturn)
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
with Side-Mounted Battery Terminals
This bulletin is being revised to update the models and provide a new labor operation number for this repair. Please discard Corporate Bulletin Numbers 02-06-04-015 and 03-06-03-006A (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on an intermittent no crank, no start condition.
Cause
This condition may be due to poor battery cable connections. Cross-threaded/stripped battery cable bolts inside the battery side post terminals may cause poor battery cable connections.
Correction
To avoid replacing the battery , do the following steps:
• Clean the threads in the battery side post terminals using a 3/8" (#16) NC bottom tap.
• Replace the battery cable bolt.
The battery cable bolt is serviced separately from the cable and is available from your Parts Department. Be sure to use the correct bolt
Old 05-14-2007 | 09:48 PM
dewmanshu's Avatar
great point, and since you are there any way with your mysterious falling out tail light, you could kill 2 birds with one beer can.
Pimpinpete
43
12-22-2017 09:13 AM
00loudchevy
12-03-2015 06:54 PM
Avalanche2002
11-30-2015 08:31 AM
bearden86
26
11-15-2015 04:58 PM
Pimpinpete
09-08-2015 08:39 PM
