what do you think?
Resident Retard
A couple of things I would change. First I would download a stock 05 tune and copy over the High and Low octance tables, and Optimum Timing table. If you don't get any knock out of those then I would copy w/ labels the Optimun Timing table and Paste w/ labels onthe High Octane table, then smooth it several times. Second I would change the PE mixture to something a little leaner. Third I would change the PE Fuel Step size, Ramp in rate, and delay rpm bypass to lower values.
Resident Retard
Here is my stock tune and also my curent tune. Compare these two tunes to see all what I changed. The current tune is very conservative, I still need to work on it some, like you I am still learning. Do you have a Wideband? If not that needs to be your next purchase, because without one your basically tuning blind....
Resident Retard
Here are some helpful links you might want to check out.
Do this first (Wideband required)
AutoVE Tutorial
http://68.178.219.18/tutorials/PDF/A...20Tutorial.pdf
Do this Next (Wideband required)
MAF tuning (post #9)
http://forum.efilive.com/showthread....hlight=maf+map
PE Enable thread (Do this last)
https://www.performancetrucks.net/fo...ighlight=b3644
AutoVE Tutorial
