What to turn off for the Flashing Battery light?
Originally Posted by blake2kz71
when i swapped pcms the first time it didnt come on but then i swapped to another 02 pcm and it came on. i think its kinda like the crank relearn code some people get it and some dont. the reason for the battery light flashing is i think the 02 and up trucks came with a bigger alternator than 99-01 and that throws the code. no biggie.
I put in a spare PCM I had from my '05 sierra... anyhow, we've turned off the code for the F terminal but the battery still flashes. I'll double check this afternoon and do another crank relearn for grins.
Originally Posted by Tootall
is there any benefit to doing this? swapping the 00 for an 05?
Maybe I'm wrong, but I was pretty sure you can not use a 03 or newer 1 meg pcm on an 02 or older 512k pcm engine/harness. The 1 meg pcm's have one of the connector on the pcm different also.
I just when out and checked the 1 meg 03+ pcm will NOT plug into an older harness, one has a red connector and the other has a green connector and they are keyed different.
Not sure... everything is working fine using the '05 PCM other than the flashing battery.
