Whats going on after wait4me install?!
So I got home from Vegas today and while I was gone had received my pcm from wait4me. Easy to install.
Only thing after I took it for a quick spin and got on it, it sounds like bbs (?) are in my engine. Is it just knock because I have regular gas and and need to go to premium? Or is it something else? Sounds like someone poured bbs in my engine is the best way I can describe it. Help.
Wow, Sounds like detonation. is it a 93 octane tune? Do you have a A/F gauge available? When I got my first W4M tune my WOT A/F was like 15+xx so I sent it back and he corrected it. But if I didn't have the gauge, the motor would be toast.... I'm not knockin him, he is good, once corrected it blew my diablosport tune away. it also could be unique to my truck, it's an 04 with a bunch of 03 stuff on it from the factory, brakes, Tstat, more I can't think of right now
He'll figure it out, and the second tune is usually better anyway cause he has some info to go by. just don't be hard on it till then.. Good Luck..
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
what you are hearing is detonation. Go put some 93 and some octain booster in it and drive it normal dont pound on it and let the tables set themselves for the higher octiain and see if the ping goes away.
Dont keep going wide open that will kill your engine. Just baby it for a few days and pump up the octain see what that does. If that dosent do it PM wheatly here he is one of the best tuners around and not much more then jesse.
I would do a crank re-learn asap, then put some higher octane gas, sounds like the pcm is running on the high octane table and you have low octane gas. Then if it doesn't get better maybe talk to Jesse about it.
LCHEE
10-24-2020 04:10 PM
GXPJAY
11-05-2015 06:49 AM
zblee
08-03-2015 03:45 AM
FlowmasterMufflers
07-17-2015 03:26 PM
