When is VE in control vs. MAF?
Old 03-12-2007 | 02:59 PM
  #31
RedHardSupra's Avatar
Originally Posted by 12secSS
By allow the ECM to add extra enrichment for harsh throttle transitions, you allow more fuel to stay in the mixture or add extra fuel caused by the vaporized fuel that has now been condense and is no longer atomized. This can also be adjusted, depending on the OS, for how long the extra enrichment is applied. I hope this helps.
any examples of how to arrive at the values for these? like if i know that i get AFR spikes to 17.5 when it supposed to be going to PE from stoich, how much do i adjust. i also imagine there'd be an adjustment for how big the injectors are too, since the amount of fuel injected would change.
Old 03-13-2007 | 03:47 AM
  #32
dc_justin's Avatar
Hello Dave
Sorry to bring up an "old" thread, but this can be helpful to this topic.
To remedy that instant lean factor when you mash the throttle, you need to adjust the fuel transient tables. Some of these table depic the pool of extra fuel left over, that the ECM uses during harsh throttle transitions. This fuel, under low pressure, tends boil over easily and allows enrichment. But when you add pressure (open the throttle) and vacuum drops (N/A) or boost rises (FI), it causes the vaporized fuel to rain on the intake port. This causes the inital lean condition you exprience. By allow the ECM to add extra enrichment for harsh throttle transitions, you allow more fuel to stay in the mixture or add extra fuel caused by the vaporized fuel that has now been condense and is no longer atomized. This can also be adjusted, depending on the OS, for how long the extra enrichment is applied. I hope this helps.
As I recall, Dewey mentioned something about that table/parameter within HPT. I personally have been unable to test it, as that is not one that is available on my OS (yet) in EFILive, but the explanation you have presented makes sense. Similar but different effect wherein fuel puddles readily in the intake ports at cold start, hence cold start enrichment is born...
Old 03-13-2007 | 10:06 AM
  #33
12secSS's Avatar
Guys,
At the moment I have played with these values only. I adjust them in small quantities and test the initial hit of the throttle, trying to lessen the AFR spike (verified by my wideband). But I was told about them from people I regard as experts in the field (quite a few to list). Definately it is based on the injector design, which I would like to see a more robust injector spreadsheet (hint hint Marcin ) that uses the injector specs and converts that data to minimum pulse width, offsets, etc ... Currently some injector info is hard to come by. Seems like this (fuel transient tables) are an uncharted territory for DIYer's.
Old 03-13-2007 | 10:28 AM
  #34
dc_justin's Avatar
Hello Dave
That's my kind of territory.
Old 03-13-2007 | 11:12 AM
  #35
Guys,
recently i came upon some math that could get us things like minimal pulse width and offsets, but we'd still need data. i'm talking with one company to get us more precise info, but that's nothing sure yet.
if you know how it works, and at least have some mockup data to play with, i'd be more than happy make a new spreadsheet, but as of right now i just dont know how this stuff works. plus, my school is really getting in the way of my education...
if you got anything on these topics, email me or something, we need this badly, i hate hacking numbers blind without understanding
Old 03-13-2007 | 11:40 AM
  #36
12secSS's Avatar
Chart on!
The only injector maker I have data from is Mototron, others are like it is a trade secret. I found a website that had an extensive list of injectors and some data, I will find it and forward it to you (could be you have stumbled upon it). I will ask those that I know (as well as make a post on the HPT forum), of how it works and relay that info to the enthusiasts. I agree about playing with numbers, I much prefer to understand their function then mearly adjusting them.
Good luck with your schooling.
Old 03-20-2007 | 10:06 PM
  #37
dewmanshu's Avatar
Moderately Differentiated
I don't see these tables in HPT. (2002 and 2003 trucks) I see the transient tab. But nothing there. ARGHGHGHGHGHGHG!!!!!!
Old 03-21-2007 | 09:41 PM
  #38
1slowsilverado's Avatar
Are you sure about the 02? http://i59.photobucket.com/albums/g2.../Transient.jpg
Old 03-21-2007 | 11:00 PM
  #39
dewmanshu's Avatar
Originally Posted by 1slowsilverado
OH SHNAP! Your right! Sorry, I didn't see it on the 2003 and jumped to conclusions. Good for me, bad for Holty.
Old 03-21-2007 | 11:31 PM
  #40
Hawk179's Avatar
What is it that you are getting AFR spikes on when going into PE?
RIck
Quick Reply: When is VE in control vs. MAF?
