Who adjusts thier tune for the 10% or up to 10% ethanol at the pump these days...
FormerVendor
I do in every tune that I setup especially locally and if not local I try and get as much info as possible about the fuel sold in the area and as far as how well their really is only one correct way to do it and that is to change the afr value in the stoichiometric table, everything else should not need to be touched as long as injector data is good and the airflow tables have been done right. The PE enrichment values also stay the same as well.
Hey Black Rado I see in your sig that you had James tune your truck, very good choice he knows very well what he is doing and does it right!
FormerVendor
Hey BlackGMC, using Lambda is an excellent way to approach tuning with our ethanol blended fuels these days, it really can simplify things. I have been tuning thinking in terms of Lambda for quite sometime now and it sure does clear up alot of confusion and overthinking with afr's.
