Who adjusts thier tune for the 10% or up to 10% ethanol at the pump these days...
#22
FormerVendor
It's a disease.
But on a serious note Ford is starting to recognize where we are heading with these ethanol blended fuels as they are starting to have some of their factory calibrations setup already for E10, I will have to double check a tune file but I believe for one if I am not mistaken the new mustangs are set to 14.1 afr
#23
Hello Dave
He won't see any power out of it, just better consistency every time he goes and re-tunes it. As it is right now, all of his wideband time results in a VE table that is at least 4-5% higher than actual, which then affects the PCMs spark reference, torque calculation, etc, etc.
#24
Wearin' da big hat
#27
don't be mad that you have had EFI Live for 1+ years and you still have no idea how to use it.
But this does answer some of my questions about the side affect/ wierd issues i have seen after retuning my truck 2 weeks ago... I like messing around with tuning, so if i have time this weekend i am going to check out the differences.
#29
from my understanding is that would affect your airmass calcs. for example: you would be referencing the wrong value in your spark table, thus your commanded spark value would be a little off... Also your IDC would be up a little bit too.
But i have a question. is E85 and E10 similar? Meaning E85 contains 85% ethanol, and E10 contains 10% ethanol? Or am i way off... if i am not does that mean if the airmass was correct would we be able to get away with a little more spark due to the higher octane rating of ethanol? Or do i have things completely wrong???
