Who adjusts thier tune for the 10% or up to 10% ethanol at the pump these days...
#31
I have a gauge for that
While the ideal stoich ratio for E10 is around 14.1, E85 is around 9.76, so you can see why you need bigger fuel system and everyones gas mileage tanks. It should be noted both values are at lambda = 1. Ethanol is a good octane booster compared to gasoline so you can up the timing a fair amount
#32
Hello Dave
from my understanding is that would affect your airmass calcs. for example: you would be referencing the wrong value in your spark table, thus your commanded spark value would be a little off... Also your IDC would be up a little bit too.
But i have a question. is E85 and E10 similar? Meaning E85 contains 85% ethanol, and E10 contains 10% ethanol? Or am i way off... if i am not does that mean if the airmass was correct would we be able to get away with a little more spark due to the higher octane rating of ethanol? Or do i have things completely wrong???
Mossyoakglock
07-17-2015 08:30 AM
