Wide Band AFR variance with temp
I was noticing in this past summer that my afr under most conditions in the 80-90 deg days is around 10.9-11.1. Winter in the real cold, as in below zero, it was closer to 11.3-11.4. Is that more or less the nature of the beast (because of air density change), or could I stand to lean it up a wee bit and still not be too lean in the cold? I ask this because when I throw the smaller pulley on I wanna know if i should aim for afr of 11 in the summer so I don't go to lean in the winter. Is there any settings I can play with that have to do with temperature compinsation?
move to cos3 you will be fine. Its in the tutorial in the scan tool. I couldnt even get my ve to set up right before moving to it.
Its Custom Operating System 3. Its free. Thanks efilive
thompson
12-27-2017 06:48 AM
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
blown02408
10-01-2015 01:06 AM
