Wideband shootout - 9 sensors tested
#32
I AM A MOTHERF*CKER
Originally Posted by thunder550
Erm... I hate to get all scientifically pissy but that test is essentially meaningless -- it's an advertising piece except for the "ease of use" and other subjective measures...
There are no controls involved at all here -- yeah, I did read about the two test gasses, but c'mon, he just held the sensor in front of the valve in a room full of room temperature air... Did he hold each sensor in exactly the same place and at the same angle? Were the sensors heated? Those two factors will make a huuge difference in an o2 sensors readings...
On the latency thing, I've played with both innovative and PLX devices -- both have a sensitivity setting that helps you get useful data. Both of these settings directly control latency... were all set to the same sensitivity? The article doesn't say, but my experiences with an LM-1 and a PLX lead me to believe that they weren't.
heh -- and in further reading, I see these points have already been raised...
#35
How do I change this text
I'm realy glad you e-mailed Dyno jet Dewey, I'm a huge fan of their wide band. I have used mine with no problems sence I got my STS kit over three years ago, after I read this ardical I was very disapointed too.
BTW I thought you knew about the sensitivity, I lowered mine until the gauge move too much and then backed it off some....
#36
Moderately Differentiated
Originally Posted by TurboBerserker
Dew -- you should add a link back to this thread for all the responses from the companies, etc.
#37
Originally Posted by bluecajun5.3
lc-1 works like a champ if they are grounded right!
they just have shitty directions.
they are finiky b/c of people not gounding them right.
I have to agree one hunred percent. My first LC-1 crapped out on me with in 2 weeks of hooking it up. I tried to hook it up somewhat portable and grounded it through the cigarette lighter plug. Innovate warrantied it. I installed the new one permanent and grounded to the engine. I am using in place of the stock narrowband and as a wideband w/ gauge in my DD. Been working great since October.
Great find on the article. I dunno bout those tests either. Most magazine articles are just propaganda anyway.
#38
Hello Dave
Back from the dead...
I learned today by someone that was at the test that the "shootout" was sponsored by Innovate... Hardly an unbiased test.
I was told in not-so-many-words to take the results with a grain of salt and not to worry about my PLX's lower score.
Were I able to go back to my PLX purchase, I would have spent a little bit more on an NGK AFX controller and purchased an NTK sensor instead of the Bosch that most of the others run.
#39
Really shitty, i'd really like to see innovative's "marketing" response to them sponsoring that. Unfortunately, but fortunately as well...the ease of the setup shoud be considred as well. You shouldn't have to go out of your way to wire these things. It's not rocket science, eerrr shouldn't be anyway.
#40
