Wideband shootout - 9 sensors tested
#41
Quote from EFILive website by Blacky .
"The best solution is to use the RS232 serial link into FlashScan and get an exact digital wide band AFR value. The serial interface is being developed for the next major FlashScan firmware update. The LC1 will be the first wide band supported by FlashScan's RS232 interface."
I will stick it out with my Innovate product .
#42
#43
Originally Posted by TurboGibbs
My laptop doesn't have a RS232 port and i've tried 2 different RS232-USB adapters messing with all the data rate's etc and failed to get them to work. I give up on Innovate.
The RS232 is on the Innovate LC-1 cable and the cable that came with V2 has a RS232 to cat5 cable that hooks directly to the V2 unit .
I'm still sticking with Innovate .
#45
#47
Mr. Obvious
Originally Posted by BlackGMC
Cat5, is a type of wire, it is the same wire that are used in computer network. If you have a cable modem or DSL, it is the large telephone wire.
some use it now for general landline phone use
#48
Category 5
http://en.wikipedia.org/wiki/Category_5_cable
My mistake it is actually a RJ-45 that the RS-232 uses on the V2 box , the Cat5 is for the OBDII connection , Sorry .
http://en.wikipedia.org/wiki/Registered_jack
#49
Moderately Differentiated
Originally Posted by your sig quote
Sometimes working out a problem can be like knocking two rocks together , sparks fly but nothing happens .
#50
Originally Posted by dewmanshu
So, it sounds as if EFI is picking up the slack for the Innovative. Which is cool, At least everybody with innovative products that doesn't work have a solution, as long as they have EFI.
kinda ironic eh?
kinda ironic eh?
Digital , more precise those 1's and 0's .
