Which Wideband would you guys recommend??
Old 08-01-2007, 07:01 PM
truckmann's Avatar
Originally Posted by dmc_racer
I think those are a waste of money... Looks to be nothing more than a narrowband sensor with a guage. You need something that can tell you what the acuall afr is not just if it is in the Stoich range.
Old 08-01-2007, 09:16 PM
LS1TECH Sponsor
foff667's Avatar
Here's a listing of some of the widebands people are using with our software/hardware package http://www.hptuners.com/forum/showthread.php?t=10510
Old 08-01-2007, 10:03 PM
Bill Reid's Avatar
AEM... the all-in-1 gauge one... works great with HP Tuners
Bill
Old 08-02-2007, 12:22 AM
ridnlow's Avatar
I have had good luck out of my LM-1.. tuned a few different vehicles with it.. Works really nice with Hp Tuners
Old 08-02-2007, 06:48 PM
Stoichiometric's Avatar
I have an LM-1 and a Wideband commander. Neither have had any problems. Someday I may install them both in the same pipe for my own shootout.
Old 08-04-2007, 12:49 PM
FormerVendor
leftcoast32's Avatar
I am using the Autometer Wide Band AFR Gauge and really like it. I had to set up a user defined PID for HP Tuner Logging but other then that it was easy. I can log with HP and watch the gauge. I put the Wide Band Sensor 6" after the Cat on Bank 1 and it reads real stable, not over sensitive.
Old 08-04-2007, 01:05 PM
Resident Retard
BlackGMC's Avatar
I thought putting the sensor after the cat will cause the AFR to be off, wouldn't the AFR read leaner??? I may be wrong but that is what I remember reading...
Old 08-04-2007, 02:59 PM
FormerVendor
I was told to do this because the Wide Band Sensor doesnt like Heat or Pressure. It actually reads great. If it is a little lean then I will always be safe. I tune by using the stock sensor and the wide band readings logged side by side.
Old 08-04-2007, 03:24 PM
Red04Silverado's Avatar
Thanks for the info
Old 08-04-2007, 04:16 PM
Senior Member
Country Boy's Avatar
I liked my LC1 and it worked fine but I have a LM1 now for the easy portability.
Quick Reply: Which Wideband would you guys recommend??
